Can Discovery and Upload be made by CLI commands?
Dear all, greetings.
I´d like to know how powerful goes the CSCP CLI because in order to use the collector in an automated way is needed to make a shellscript to run on the environment or remotely or via Ansible.
I'm questioning that because I´m in a project with a client that has multiple environments and will need to run around 30>, Collectors.
adias
   The CSPC server for SNTC service is designed as a standalone server and the present hardening security scripts defaults do not allow external access to the server other from its intended applications settings.  customized scripts are not one of this settings.  The Server web application has a scheduler to which Discoveries,  Collection and uploads can be set on specific periodic schedules. So not sure what would be the use case to manage this settings remotely for SNTC service.
