Can we mix mandatory and optional field entries for file import?
Gregory Tessler
Can we have devices with mandatory fields only and some other devices with mandatory and optional fields within the same CSV file used for file import?
Hi Rita and Sandra,
That is correct, you can mix mandatory and optional field entries for file import. However, if you don’t have OS type and version, the alerts matching would be impacted.
June
Rita Livezey
I think you can. I have seen sample files with both.
Hi Rita and Sandra,
June
