Cannot access Contracts api in Mulesoft
EvaNajera57061
I have API Developer role in apiconsole given by our DA but I cannot register an application to access Contracts in Mulesoft due to insufficient permissions??   Assistance would be much appreciated.
Eva
10 Replies 10
Supriya Patel
Hi Eva,
Please share screenshot of error that you receive. As well, please do let me know if you are able to register other CSAPI application under Mulesoft.
Supriya
EvaNajera57061
Hi Supriya!
I've tried the other csapi's but received same error for each. See attached screenshot of error.
Hi Eva,
Thanks for your reply on this. I am working with related team on given issue so i will update you as I hear back.
Supriya
Hi Eva,
Team has an ongoing issue with Developer portal and they are working with Mulesoft vendor to resolve it, for now can you please provide below details via private message so that related team will grant user access to API from backend as a workaround.
API Name to which they are requesting access
Client Application Name created by user/partner
User id
Party id / customer company name
Supriya
Hi Eva,
I have received your private message and working with related team. I will update you soon as I hear back.
Supriya
Hi Eva,
Sorry for delay in reply. I am trying to replicate and would like to know if you are having issue with customer-info/customer-details or any other API. So, I can reach out to team accordingly for all APIs that you have question with.
https://apx.cisco.com/cs/api/v1/customer-info/customer-details
Supriya
Hi yes after registering my app successfully with csapi-contracts and csapi-customer, I am getting 403 errors for both these API's. I can get a token when posting to https://cloudsso.cisco.com/as/token.oauth2 using client credentials but when I, for example attempt to invoke a get request to 'https://apx.cisco.com/cs/api/v1/customer-info/customer-details'  I get a 403 with msg. 'Please provide a valid token'.
Hello @EvaNajera57061
Can you verify that the token is being added to the request header and not the request URL?
Thank you
Yes, I can confirm I am adding the token to header of the request.
@jofrumki @Supriya Patel  Any update on this?
