Collector upload fails with error 404 Not Found
cmortimer1
I have a collector that was working fine and now for the past 2 weeks when trying to upload it comes back with a 404 not Found Error. We are running 2.8.1.3 currently. I have ran packet captures and see the bidirectional traffic between my collector and the Cloud and do not see anything getting blocked. I have verified connectivity to the Upload URL and get the message back "It Works" from the website. I have rebuilt the collector from the ground up and re-certified it multiple times in the Portal. Yet no matter what I still get 404 and cannot find anything to indicate why.
16 Replies 16
brawall
Can you share a screenshot of the error as well as the appliance ID of the collector?
CSP0009040738: A connectivity exception occured while processing the request. The Exception is :: HTTPs TransportMode has Failed 404:Not Found
Bump
Can you share output of curl --tlsv1.2 https://concsoweb-prd.cisco.com/HeadEndWebAppServlet/ -v -k from the cli?
Brandon
* About to connect() to concsoweb-prd.cisco.com port 443 (#0)
* Trying 72.163.7.113... connected
* Connected to concsoweb-prd.cisco.com (72.163.7.113) port 443 (#0)
* Initializing NSS with certpath: sql:/etc/pki/nssdb
* warning: ignoring value of ssl.verifyhost
* skipping SSL peer certificate verification
* SSL connection using TLS_RSA_WITH_AES_256_CBC_SHA
* Server certificate:
* subject: CN=concsoweb-prd.cisco.com,O="Cisco Systems, Inc.",L=San Jose,ST=CA,C=US
* start date: Feb 26 18:55:03 2019 GMT
* expire date: Feb 26 19:05:00 2021 GMT
* common name: concsoweb-prd.cisco.com
* issuer: CN=HydrantID SSL ICA G2,O=HydrantID (Avalanche Cloud Corporation),C=US
> GET /HeadEndWebAppServlet/ HTTP/1.1
> User-Agent: curl/7.19.7 (x86_64-redhat-linux-gnu) libcurl/7.19.7 NSS/3.27.1 zlib/1.2.3 libidn/1.18 libssh2/1.4.2
> Host: concsoweb-prd.cisco.com
> Accept: */*
< HTTP/1.1 302 Found
< Date: Tue, 21 May 2019 16:31:43 GMT
< Server: Apache
< Set-Cookie: ObSSOCookie=loggedoutcontinue; path=/; domain=.cisco.com
< Location: https://sso.cisco.com/obrareq.cgi?wh%3DConn-Prod%20wu%3D%2FHeadEndWebAppServlet%2F%20wo%3D1%20rh%3Dhttp%3A%2F%2Fconcsoweb-prd.cisco.com%20ru%3D%252FHeadEndWebAppServlet%252F
< Content-Length: 357
< Cache-Control: max-age=0
< Expires: Tue, 21 May 2019 16:31:43 GMT
< Content-Type: text/html; charset=iso-8859-1
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>302 Found</title>
</head><body>
<h1>Found</h1>
<p>The document has moved <a href="https://sso.cisco.com/obrareq.cgi?wh%3DConn-Prod%20wu%3D%2FHeadEndWebAppServlet%2F%20wo%3D1%20rh%3Dhttp%3A%2F%2Fconcsoweb-prd.cisco.com%20ru%3D%252FHeadEndWebAppServlet%252F">here</a>.</p>
</body></html>
* Connection #0 to host concsoweb-prd.cisco.com left intact
* Closing connection #0
Can you share the same but without the "-k" flag?
* CAfile: /etc/pki/tls/certs/ca-bundle.crt
CApath: none
> Accept: */*
< Date: Tue, 21 May 2019 16:38:03 GMT
< Server: Apache
< Expires: Tue, 21 May 2019 16:38:03 GMT
<html><head>
</head><body>
<h1>Found</h1>
</body></html>
Can you share the appliance ID and version of collector? Has it been upgraded or is it on the same version that it was deployed on?
It has been upgraded, rebuilt fresh, and so on. I originally built a brand new Collector to replace the old one and the new one worked fine for a couple weeks. Then this started. I upgraded it after the fact to see if that would help, but it didn't. I rebuilt it fresh again and still was not working.
Applicane ID: CSP0009040738
Version: 2.8.1.3
Can you PM the contents of the file located at /opt/ConcsoTgw/tail-end-gateway-decoupled/conf/csof_config.xml
Also do you require a proxy server for uploads/internet access?
File Contents Sent. Yes we have a Proxy for Internet Access. I do not have it configured on the CSPC itself. We have WCCP in place to redirect HTTP(s) traffic to the Proxy. I have put in exceptions in WCCP to bypass the Proxy and it has not made a difference.
Can we try enabling the proxy settings on the collector?
"conf proxy <ip address> <port> <user> <pass>"  where user and pass are optional. After this reboot and share with me again the output of "service concsotgw restart"
Brandon
For Some reason I cannot login using Admin, I get the following error:
*****PID file exists. But Adminshell service is not completely up.*****
*****If adminshell is restarted manually, please wait for 15-20 mins .*****
*****If adminshell is not restarted manually Please check nohup.out log at /opt/cisco/ss/adminshell/logs for any errors .*****
*****Try restarting adminshell once using 'service adminshell restart' command .*****
I can login with root and collectorlogin, but then I do not get the adminshell to run the commands. When Trying to configure the Proxy Settings in the GUI, it fails to configure the Proxy Settings.
Is admin accessible after restarting it via root?
