CSPC 2.8 - CLI : Not able to get Basic details of device
eiver_fori
Greetings Community,
I have a CSPC 2.8 collector installed and I am trying to collect data from an ASA5506H-X with FTD software, but every time I try this, it tells me the following: "CLI: Not able to get Basic details of device".
Is it possible to collect data with CSPC 2.8 to devices with FTD software?
dan.agache
How do you solve this problem?
I have the same problem.
Thank you.
SHUZIJUN
Yes, I have the problem, too. I have checked the Network connectivity and SNMP configuration that are normal.
And also checked the firewall policy.  But still cannot solve it.
ibaenadi
Hello Sir,
Thank you for contacting Cisco and Global CX - Smart Services Support Team.
We are investigating your request; I'll be with you in a moment.
Kindly regards,
Ivonne Baena
ibaenadi
Hello Sir,
Please check the SNMP Configuration on 5506X FTD
There's no SNMP setting/option in FDM under device or system setting.
you can do it via its flexconfig. see helpful link:
https://www.cisco.com/c/en/us/td/docs/security/firepower/623/fdm/fptd-fdm-config-guide-623/fptd-fdm-advanced.html#task_36ECF548DADB4200A448CC163B03ADB0
