Hi, not sure if you can change the "Job Name" but you can add a description if that is what you are referring to.
Reports > Discovery Jobs > right click on the discovery and select "Modify Discovery Job" click next and there is a box for a description "Job Details", enter your description and select finish. This is what I use to describe the particular discovery. Hope it helps.
Chris
