CSPC Upload Failing
dustman86
We recently had to redeploy our CSPC server as the original was in a bad state and the account (collectorlogin, root, admin) passwords no longer worked.
After deploying the 2.10.0.1 ova and registered it I found that attempting to update via the webui would fail with the following error:
500 the call failed on the server; see server log for details
Using the following guide I was able to manually update to 2.10.0.4 by downloading and copying the files to the server.
https://www.cisco.com/c/dam/en/us/support/docs/cloud-systems-management/common-services-platform-collector-cspc/CSPC-Upgrade-Guide.pdf
I scheduled the server to run an inventory on Saturday's and to upload the data to SNTC on Sunday's, however the upload is failing.
Below is the related job log:
Upload INITIALIZING: RUNNING
Upload INITIALIZING: SUCCESSFUL
Upload SELECTING_DEVICES: RUNNING
Upload SELECTING_DEVICES: SUCCESSFUL; Other Details: 128 devices selected
Upload SEGMENTING: RUNNING
Upload SEGMENTING: SUCCESSFUL
Upload EXPORTING: RUNNING; Directory: _xxxxxxxx/10_1; Other Details: transport-inventory-1667188680048.zip
Upload EXPORTING: SUCCESSFUL; Directory: _xxxxxxxxxxxx/10_1; Other Details: transport-inventory-1667188680048.zip
Upload UPLOADING: RUNNING; Certificate: CSPxxxxxxxxxx; Directory: _Ping_Upload/10_1; File: transport-inventory-1667188680048.zip; Other Details: Upload method is Connectivity
Upload UPLOADING: MONITORING_TIMED_OUT; Certificate: CSPxxxxxxxxxx; Directory: _xxxxxxxxx/10_1; File: transport-inventory-1667188680048.zip; Other Details: No response from the connectivity module
Upload CLEANING_UP: RUNNING
Upload CLEANING_UP: SUCCESSFUL; Other Details: CSPxxxxxxxxxxxxxx: No response from the connectivity module
vivekcha@cisco.com
Hi dustman86,
Hope you are you doing well!
We are looking into the issue and get back to you with an update.
Thanks & Regards,
Vivek Chauhan
Hi dustman86,
Please share your email id and name of the company.
Thanks & Regards,
Vivek Chauhan
Vivek,
Here is the info you requested:
dtorbet@pingidentity.com
Ping Identity Corporation
Resolution Summary:
+Informed the customer that:
Upon checking we found that the cspc is still uploading the data successfully to the portal with the new created inventory and the last successful upload date is 6th November.
And its working with the correct cspc appliance id which they were trying to get to work.
