CSPC upload | HTTPs TransportMode has Failed 404:Not Found
bcagney07
Please assist with the below error on first CSPC upload. I'm also not seeing Administration > Upload Processing in the SNTC portal - not sure if this is part of the problem or the result of the upload error. Thanks!
Upload UPLOADING: FAILED; Certificate: CSP0009048946; Directory: exportdata; File: CPExport_1596212314508.zip; Other Details: A connectivity exception occured while processing the request. The Exception is :: HTTPs TransportMode has Failed 404:Not Found
adias
In deploying the  image  you would have created the cli admin password?  (java based shell authentication is not the same as the GUI)
If so have you also created/activated  the users collectorlogin and root ? (real linux shell)
If not do the following for the cli admin  shell
admin# pwdreset root 90
And
admin# pwdreset collectorlogin 90
it will activate those accounts and generate their passwords  ( keep them where you can refer to them in the future)
after that
Via SSH Login to collector as user collectorlogin and then use command below to connect as root (cannot connect directly)
# su root
and then the following commands :
# sed -i ':a;N;$!ba;s/file/#file/1' /opt/ConcsoTgw/tail-end-gateway-decoupled/bin/run.sh
# sed -i 's/nettools-upload.cisco.com/72.163.7.113/g' /opt/ConcsoTgw/tail-end-gateway-decoupled/conf/csof_config.xml
# service concsotgw restart
# service cspc restart
Once they are done try the collection profile/upload again and let me know
REF: https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvo43779
It is does not work or present a different error please send me the following in Private message
# tail -100 /opt/ConcsoTgw/tail-end-gateway-decoupled/bin/CONN_TEG_LOGS/tail-end-gateway.log
# openssl s_client -showcerts -connect concsoweb-prd.cisco.com:443
# tail -100 /opt/ConcsoTgw/tail-end-gateway-decoupled/bin/nohup.out
# wget https://72.163.7.113/HeadEndWebAppServlet/ --no-check-certificate
adias
And
after that
# su root
That worked, thanks!
