CSPC XMLAPI Error - javax.net.ssl.SSLHandshakeException
Using Python and Postman to post a request to the XML API and getting the following response on both:
Unable to connect to CSPC Server: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path validation failed: java.security.cert.CertPathValidatorException: Path does not chain with any of the trust anchors.
This code previously worked and running the same code against another instance of CSPC we have running successfully connects.  Any ideas.
jelopezm
Hello nathan.reeves@woodside.com.au
Thank you for contacting Cisco Smart Services.
Based on the description you have provided, please confirm the following information in a private message so we can check further.
* Which collector version are you running?
* Is this a new deployment or it was working before?
* Has this issue been witnessed before? If yes, since when?
* Has there been any new configuration implemented recently in the CSPC GUI? or SSL certificate?
* Can you provide a screenshot of the issue?
* Example of the code (if possible)
* Any other detail you consider important to be shared.
Best regards,
Jesus
