09-14-2017 06:12 AM - edited 03-12-2019 07:29 AM
Need to update the software version for ASA5525. Original CSV upload did not include software version. How do I update this information to add software versiona and image name?
Solved! Go to Solution.
09-14-2017 06:21 AM
Hello Teater,
You can update the OS Version of your ASA device by including the new OS Version in the original CSV file for the device row and importing it into the Portal for processing. You can also include a Software Type (ASA/IOS/NX-OS) in the CSV File, but unfortunately imagenames are not currently supported for CSV.
Thank you,
Jarrett
09-14-2017 06:21 AM
Hello Teater,
Thank you,
Jarrett
