09-16-2016 01:48 PM
I am new to SNTC & CSAM as well.
I have created / associated users with my company in CSAM,,, so that they can use Cisco Smartnet Total Care.
I am having a problem "nominating an administrator". I have associated this person with my company.
I got an error message as I was nominating him as an admin.
>>> WHAT DOES THIS MESSAGE MEAN / /// HOW CAN I FIX THE USERS ACCESS ? <<<
"This user is already associated to party 2708871. In order to nominate them as a Delegated Admin for this party, you must first disassociate them from that party. Note that any existing role assignments from that party will be inactivated when the user is disassociated. "
09-16-2016 04:06 PM
It looks like you have users associated to two different registered locations of your company. We organize those locations ("parties") into a hierarchy reflective of the legal structure of your company. I see that you are the DA for the top "headquarters" party, while the individual you want to nominate as DA is currently associated to the lower-level party.
Assuming there is a reason why you want to keep your users grouped by location (instead of having everyone associated to the headquarters, which is the typical default, for simplicity purposes), you have two choices:
1.) If you want this new person to be an administrator only for users of the lower-level (subsidiary) location, then in Step 3 (Select Company), choose their current lower-level company location (instead of your headquarters location).
2.) If you want this new person to be an administrator for all users, at your top-level headquarters and all lower-level company locations, then you can use the "User-Company Associations > Change a User's Company Association" page to move them up to the headquarters location. Once that is done, you would be able to nominate them to be an additional DA for the headquarters and all lower-level locations.
If you don't have any need or desire to manage user access across multiple locations, then you can use the same above-referenced function to move all users to the headquarters location.
More information about managing access across multi-level company hierarchies is available via the "Help" link in the upper right corner of every CSAM page.
