01-11-2012 08:03 AM
Is there any APIs that we can use to look up information the description and warranty/Smartnet based on a serial number?
We are building our own inventory management system and I have serial numbers of the Cisco devices.
Screen scraping from http://tools.cisco.com/scc/ is not how we want to handle thousands of devices.
We would like to integrate our service with cisco.com directly to pull any information..
email is rsmith@rsmith.edu
01-31-2017 10:09 AM
Yes it still works, we use it every day.
Go to https://apiconsole.cisco.com/ and sign-in/register. The API instructions are pretty good. Just start with the Hello API to make sure your access token code works, then start integrating the other APIs.
01-31-2017 10:59 AM
Thanks a lot!
02-02-2017 07:24 AM
Sorry I'm a beginner on this, but if it doesn't appears in the options, does it mean that I can't use it? or can I add Serial number to information API with other method?
These are all the options that I have:
02-02-2017 07:45 AM
Yes there are quite a few more than that, including SN2INFOv2. I don't know the rules around access levels to each API (e.g., are some partner only?).
I would send your CCO ID and access request to:
02-02-2017 07:47 AM
Ok, thank you!
08-31-2017 01:59 PM
