Hi!
I'm developing an application as a customer.
I've registered a new application in Cisco API Developer Portal. I can successfully generate an access token but I receive an "Access Denied" message (403 Forbidden) when I access the following endpoint: https://apx.cisco.com/cs/api/v1/customer-info/customer-details. I'm trying to obtain the customerId for my customer so I can access the other Services API endpoints.
I've registered another application in the Cisco API Portal and this application works fine with the Support API endpoints (e.g. SN2info).
I'm using Postman and CURL to troubleshoot the issue.
Greg
