03-05-2018 05:31 AM - edited 03-12-2019 07:41 AM
I haven't found a way to send my SNTC portal scheduled reports to an email address... or any other way to fetch it.
Is this kind of feature available?
Thanking you in advance?
Renaud
Solved! Go to Solution.
03-05-2018 06:14 AM
Hello Renaud,
Under the Scheduled Report tab you can select the report you want to download and set up the report to run on a specific day of the month (Set up Recurrence). The system will send you a ‘Scheduled report completion’ email which contains a hyperlink to the report. You do not need to log into portal to get access. Follow the hyperlink in the email and the report will download after the user ID is authenticated.
Regards, Tim
03-05-2018 06:14 AM
Hello Renaud,
Regards, Tim
03-05-2018 06:18 AM
Thank you Tim!
Renaud
