11-28-2016 11:50 AM - last edited on 07-27-2018 10:40 AM by Cheri Fairbrother
hi everyone ...
first i upload two CSV file of my cisco switch Catalyst4500E
i upload it my SNTC the upload done with start and end processing date
But no result shown in SNTC ... ??? why ??
after that i try to use CSPC and i upload many uploads to SNTC successfully ... But not shown in upload processing
My Collectors :
01-25-2017 08:50 PM
Hi Alaa,
Are you still facing the issue?I noticed correct data under upload processing .
Anusha.
05-22-2019 06:51 AM
05-22-2019 07:07 AM
Hi Ivan,
Please check if you have completed a data collection for your devices prior to upload.
The "Discovery" to add your devices to the collector is only the first step.
Ye
05-22-2019 07:18 AM
Hi Ye,
I have completed the discovery, and even tried manually to collect and upload data - it had the same result. Here is the latest collection in SNTC showing that devices have been collected:
05-22-2019 08:01 AM
Hi Ivan,
In the CSPC Collector, go to "Reports -> Inventory Collection Reports -> View Collected Data -> View Data". Pick a node and scroll through the datasets.
That will show you if the collector was able to gather all the device information or if there was an error.
Ye
05-22-2019 08:30 AM
It shows "SNMP Successful" and "CLI Failed" - because I have it setup to collect through SNMP.
05-22-2019 09:07 AM
Under Select Dataset, pick ENTITY-MIB_entPhysical and check if there is any device information collected like serial numbers. If the dataset is empty, then there is an issue with SNMP.
05-22-2019 10:04 AM
Yes, it is able to collect the serial numbers:
05-22-2019 11:04 AM
Hi Ivan,
Looks like the upload from today was processed and included all the collected data. Your devices and contracts are available on the Portal now.
Ye
05-22-2019 11:35 AM
Hi Ye,
Not sure what happened, but now I can see the data. Thank you very much.
P.S. Is there anything I can do myself, if the issue repeats?
