ā08-14-2017 12:43 PM
I'm trying to upgrade the
So I would like to try the upgrade via CLI but I can not find the software or instruction on CLI to install it.
Can someone supply both the software and the install instruction for
Solved! Go to Solution.
ā08-14-2017 05:31 PM
Hi User,
SNTC customer found 2.7 more stable image so far. In case, if you still want to upgrade, please apply command 'service adminshell restart' from user CLI login 'root' and retry installing from GUI. Or upgrade via LCM as given in document. Document can be found on 'software update' tab when you click 'more'. Please let me how it goes and if you have any more question. If any error, please supply me with screenshot.
Supirya
Hi User,
Supirya
