Filtering a field by not equal to value
In the SNTC portal is there a way to filter a column to show only values that are != value. Value being the variable I want to filter out. Under custom inventory I have it set it to show all equipment with end of life dates. I want it to stop the portal from displaying the transceiver modules so I do not have to manually remove them after I generate a report.
Hi Timothy,
The SNTC portal does not allow for filtering out in the Product Family column.  As you've discovered, working with the offline report gives you the most flexibility with the data.
Cheers,
Cheri
