09-11-2018 08:05 AM
There appears to be an issue with the output of the Macro Report v3.6 where the 'Custom Inventory' tab appears to have the headers and data mis-aligned.
As an example, Column E, has headings of 'Equipment Type' & 'SNMP Location' but the data rows contain the equipment type - Chassis / Power Supply / Fan.
This data issue then means that other output from the report is incorrect.
The current macro version I am running is 3.6 - has a new version been released or is there an issue with the reports from the portal?
Andy
Solved! Go to Solution.
09-11-2018 08:20 AM
Hi Andrew,
We do have an updated version of the Macro available on our SNTC Portal page!
Feel free to bookmark the SNTC Offline Macro Report itself and pull a fresh copy to ensure using the most up-to-date version.
Cheers,
Cheri
09-11-2018 08:20 AM
Hi Andrew,
Cheers,
Cheri
