Service pack issues (Collector Upgrade from 2.9.0.2 to 2.9.1)
scottyd
I am unable to apply the patch. Below is the error.
[Fri Oct 1 10:45:12 NZDT 2021] Apply TCL Called with arguments "SP" and "sp-30.2.1-1-0-lnx64.zip"
[Fri Oct 1 10:45:12 NZDT 2021] Inside existence of status db
[Fri Oct 1 10:45:27 NZDT 2021] Parsing package info
[Fri Oct 1 10:45:29 NZDT 2021] Validating package details
[Fri Oct 1 10:45:33 NZDT 2021] Parsing Component info
[Fri Oct 1 10:45:33 NZDT 2021] Validating Component info
[Fri Oct 1 10:45:33 NZDT 2021] Checking component dependency
[Fri Oct 1 10:45:33 NZDT 2021] Apply TCL returned 1
[Fri Oct 1 10:45:33 NZDT 2021] Executing pre-install scripts
[Fri Oct 1 10:49:10 NZDT 2021] Removing old Kernels
Inside preinstall script
Fetching Version info
Initializing SP Patch installation .....
Updated CASP
current CSPC version is : 2.9.0.2 and casp version is : 2.9.1.1
Current CSPC version 2.9.0.2
SP 2.9.1.1 can install on 2.9.1 and above only
child process exited abnormally
I believe the JeOS patch installed ok:
update next package to install
[Fri Oct 1 09:50:44 NZDT 2021] End of Script Execution
[Fri Oct 1 09:50:44 NZDT 2021] End of Procedure
[Fri Oct 1 09:50:44 NZDT 2021] Executing post-install scripts
Current SP :
Current JeOS :
Service Name : COLLECTOR
Hostname : nplcspc01.hiq.net.nz
Timezone : NZDT
Replaced scripts with Derby statements
[Fri Oct 1 09:52:24 NZDT 2021] Executed post-install scripts
[Fri Oct 1 09:52:24 NZDT 2021] Installation of software package of type "JeOS" completed successfully
[Fri Oct 1 09:52:25 NZDT 2021] --Component--CASP--CASP |Component |JeOS |2.9.1.1 |CASP component |1614307872--jeos-30.2.0-2-lnx64--
[Fri Oct 1 09:52:25 NZDT 2021] else block of status update
[Fri Oct 1 09:52:25 NZDT 2021] update version--2.9.1---CASP---Component-------
[Fri Oct 1 09:52:26 NZDT 2021] --Component--ConcsoTgw--ConcsoTgw |Component |JeOS |1.8.0 |Connectivity TGW component |1614307873--jeos-30.2.0-2-lnx64--
[Fri Oct 1 09:52:26 NZDT 2021] else block of status update
[Fri Oct 1 09:52:26 NZDT 2021] update version--1.8.0---ConcsoTgw---Component-------
[Fri Oct 1 09:52:27 NZDT 2021] --Component--AdminShell--AdminShell |Component |JeOS |1.9.4 |AdminShell component |1614307874--jeos-30.2.0-2-lnx64--
[Fri Oct 1 09:52:27 NZDT 2021] else block of status update
[Fri Oct 1 09:52:27 NZDT 2021] update version--1.9.4---AdminShell---Component-------
[Fri Oct 1 09:52:27 NZDT 2021] --Component--LCM--LCM |Component |JeOS |1.9.4 |LCM component |1614307875--jeos-30.2.0-2-lnx64--
[Fri Oct 1 09:52:27 NZDT 2021] update version--1.9.4---LCM---Component-------
[Fri Oct 1 09:52:28 NZDT 2021] --Component--Hardened CentOS--Hardened CentOS |Component |JeOS |8.1 patch#0 |Hardened CentOS |1614307876--jeos-30.2.0-2-lnx64--
[Fri Oct 1 09:52:28 NZDT 2021] else block of status update
[Fri Oct 1 09:52:28 NZDT 2021] update version--8.1 patch#0---Hardened CentOS---Component-------
[Fri Oct 1 09:52:29 NZDT 2021] --JeOS--JeOS--JeOS |JeOS | |jeos-30.2.1-1-lnx64 |Appliance Base Package patch update |1633034784--jeos-30.2.0-2-lnx64--
[Fri Oct 1 09:52:29 NZDT 2021] else block of status update
[Fri Oct 1 09:52:29 NZDT 2021] update version--jeos-30.2.1-1-lnx64---JeOS---JeOS-------
[Fri Oct 1 09:52:30 NZDT 2021] status db updation completed
6 Replies 6
aibhatna
Hi scottyd,
Hope you are you doing well!
We are looking into the issue you posted. We will reach out to you soon with an update.
Thank you
Aishwarya Bhatnagar
Hi scottyd,
We request you to please download the patch for 2.9.1 again and apply it.
Link to download Patch:   https://software.cisco.com/download/home/286312935/type/286312958/release/2.9.1
How to apply patch : https://www.cisco.com/c/dam/en/us/support/docs/cloud-systems-management/common-services-platform-collector-cspc/CSPC-Upgrade-Guide.pdf
Let us know if the issue still persists.
Thanks & Regards
Thanks.
This is the session of the install.
But this is the result of show version
Cisco Network Appliance Administration
To see the list of all the commands press '?'
admin#
admin# sh ver
Build-name : Collection Platform Software 2.9.0.2
Version : sp-30.2.0-2-0-lnx64
admin#
Install
[root@nplcspc01 opt]#
[root@nplcspc01 opt]# unzip collector_2.9.1_Build-05.zip
Archive: collector_2.9.1_Build-05.zip
creating: collector_2.9.1_Build-05/
inflating: collector_2.9.1_Build-05/install.sh
extracting: collector_2.9.1_Build-05/jeos-30.2.1-0-lnx64.zip
extracting: collector_2.9.1_Build-05/sp-30.2.1-0-0-lnx64.zip
[root@nplcspc01 opt]# ls
backup cisco collector_2.9.1_Build-05 ConcsoTgw install.sh jeos-30.2.1-1-lnx64.zip LCM sp-30.2.1-1-0-lnx64.zip
build.txt cleanup.sh collector_2.9.1_Build-05.zip ConcsoTgw.1633034998.zip java Jetty sntc.txt wmi
[root@nplcspc01 opt]# cd collector_2.9.1_Build-05
[root@nplcspc01 collector_2.9.1_Build-05]# ls
install.sh jeos-30.2.1-0-lnx64.zip sp-30.2.1-0-0-lnx64.zip
[root@nplcspc01 collector_2.9.1_Build-05]# ./install.sh JeOS jeos-30.2.1-0-lnx64.zip
Appliance will auto reboot once the patch installation is completed. Press [y/Y] to proceed for installation, any other key to exit :y
Installing JeOS patch...
Patch installation in-progress, system will auto reboot once the patch installation is completed.
Kindly refer the logs in /opt/LCM/logs/ directory for more information.
[root@nplcspc01 collector_2.9.1_Build-05]# Logging installation - CSPC Home exists
[root@nplcspc01 collector_2.9.1_Build-05]# tail -f /opt/LCM/logs/apply
Updated CASP
[Wed Oct 6 09:18:07 NZDT 2021] Apply TCL Called with arguments "JeOS" and "jeos-30.2.1-0-lnx64.zip"
[Wed Oct 6 09:18:07 NZDT 2021] Inside existence of status db
[Wed Oct 6 09:18:47 NZDT 2021] Parsing package info
[Wed Oct 6 09:18:58 NZDT 2021] Validating package details
[Wed Oct 6 09:19:22 NZDT 2021] Parsing Component info
[Wed Oct 6 09:19:22 NZDT 2021] Validating Component info
[Wed Oct 6 09:19:23 NZDT 2021] Parsing Component info
[Wed Oct 6 09:19:23 NZDT 2021] Validating Component info
[Wed Oct 6 09:19:23 NZDT 2021] Checking component dependency
[Wed Oct 6 09:19:23 NZDT 2021] Apply TCL returned 1
[Wed Oct 6 09:19:30 NZDT 2021] ==Dep_Version--_ANY_--Dep_Version--Hardened CentOS==
[Wed Oct 6 09:19:30 NZDT 2021] Inside _ANY_
[Wed Oct 6 09:19:31 NZDT 2021] ======Hardened CentOS |Component |JeOS |8.1 patch#0 |Hardened CentOS |1633035148----
[Wed Oct 6 09:19:31 NZDT 2021] Cyclic dependency check
[Wed Oct 6 09:19:31 NZDT 2021] Apply TCL returned 1
[Wed Oct 6 09:19:31 NZDT 2021] Checking component dependency
[Wed Oct 6 09:19:32 NZDT 2021] ==Dep_Version--_ANY_--Dep_Version--LCM==
[Wed Oct 6 09:19:32 NZDT 2021] Inside _ANY_
[Wed Oct 6 09:19:32 NZDT 2021] ======LCM |Component |JeOS |1.9.4 |LCM component |1633035147----
[Wed Oct 6 09:19:33 NZDT 2021] ==Dep_Version--_ANY_--Dep_Version--Hardened CentOS==
[Wed Oct 6 09:19:33 NZDT 2021] Inside _ANY_
[Wed Oct 6 09:19:33 NZDT 2021] ======Hardened CentOS |Component |JeOS |8.1 patch#0 |Hardened CentOS |1633035148----
[Wed Oct 6 09:19:33 NZDT 2021] Cyclic dependency check
[Wed Oct 6 09:19:33 NZDT 2021] Apply TCL returned 1
[Wed Oct 6 09:19:33 NZDT 2021] Checking component dependency
[Wed Oct 6 09:19:34 NZDT 2021] ==Dep_Version--_ANY_--Dep_Version--Hardened CentOS==
[Wed Oct 6 09:19:34 NZDT 2021] Inside _ANY_
[Wed Oct 6 09:19:34 NZDT 2021] ======Hardened CentOS |Component |JeOS |8.1 patch#0 |Hardened CentOS |1633035148----
[Wed Oct 6 09:19:34 NZDT 2021] Apply TCL returned 1
[Wed Oct 6 09:19:34 NZDT 2021] Checking component dependency
[Wed Oct 6 09:19:35 NZDT 2021] ======Hardened CentOS |Component |JeOS |8.1 patch#0 |Hardened CentOS |1633035148----
[Wed Oct 6 09:19:35 NZDT 2021] ==Dep_Version--_ANY_--Dep_Version--AdminShell==
[Wed Oct 6 09:19:35 NZDT 2021] Inside _ANY_
[Wed Oct 6 09:19:36 NZDT 2021] ======AdminShell |Component |JeOS |1.9.4 |AdminShell component |1633035147----
[Wed Oct 6 09:19:36 NZDT 2021] ==Dep_Version--_ANY_--Dep_Version--LCM==
[Wed Oct 6 09:19:36 NZDT 2021] Inside _ANY_
[Wed Oct 6 09:19:37 NZDT 2021] ======LCM |Component |JeOS |1.9.4 |LCM component |1633035147----
[Wed Oct 6 09:19:37 NZDT 2021] Cyclic dependency check
[Wed Oct 6 09:19:37 NZDT 2021] Apply TCL returned 1
[Wed Oct 6 09:19:37 NZDT 2021] Executing pre-install scripts
[Wed Oct 6 09:19:38 NZDT 2021] Latest or 'jeos-30.2.1-0-lnx64' JeOS patch is already installed , so exiting from installation....
1633465087
^C
[root@nplcspc01 collector_2.9.1_Build-05]# ./install.sh SP sp-30.2.1-0-0-lnx64.zip
Installing SP patch...
[Wed Oct 6 09:24:24 NZDT 2021] Apply TCL Called with arguments "SP" and "sp-30.2.1-0-0-lnx64.zip"
[Wed Oct 6 09:24:24 NZDT 2021] Inside existence of status db
[Wed Oct 6 09:25:02 NZDT 2021] Parsing package info
[Wed Oct 6 09:25:13 NZDT 2021] Validating package details
[Wed Oct 6 09:25:34 NZDT 2021] Parsing Component info
[Wed Oct 6 09:25:34 NZDT 2021] Validating Component info
[Wed Oct 6 09:25:34 NZDT 2021] Checking component dependency
[Wed Oct 6 09:25:34 NZDT 2021] Apply TCL returned 1
[Wed Oct 6 09:25:34 NZDT 2021] Executing pre-install scripts
^C
scottyd
From the GUI
Thoroughly confused now.
When I go to the update tab
Hi scottyd,
I'm sharing command in PM , let me know the output for the command for further assistance  in PM.
Thanks & Regards
Aishwarya Bhatnagar
Hi scottyd,
The customer has successfully upgraded to 2.9.1 after applying the SP patch again.
Further, they wanted to upgrade to 2.9.1.1 , hence shared the patch link to be applied for the 2.9.1.1 version on the CSPC.
Link to download the Patch : https://software.cisco.com/download/home/286312935/type/286312958/release/2.9.1.1
The Customer has successfully upgraded to 2.9.1.1 now.
Thank you
Aishwarya Bhatnagar
