10Ge switch for storage
aotholland
Hi Experts,
Can anyone recommend me a 2 X 24 ports 10Ge iSCSI Switch (Stack)
These switch will be use our storage solutions with 10Gb iSCSI redundant controller and network interfaces.
Thanks.
Mike Hale
Well...you're on a Cisco forum, so we'd be remiss in not recommending Cisco gear.
The Nexus 5548UP is around 17k for the base model without any special layer 3 licenses.
http://www.softchoice.com/catalog/en-us/hubs-switches-cisco-nexus-5548up-switch-managed-N5K-C5548UP-FA-HV7684
If you don't use layer 3 on the Nexus (which I wouldn't), they've got pretty good port density for the cost.  NXOS takes little bit of getting used to and, for us, the copper SFPs have been a royal pain in the ass, but otherwise, they're pretty solid devices.
Peter Thomas
How about the 4500X series?
They provide VSS across the stacks for redundancy and come in several port densities.
http://www.cisco.com/en/US/prod/collateral/switches/ps10902/ps12332/data_sheet_c78-696791.html
Probably cheaper than a Nexus if you are on a budget but be careful what you are connecting to them as the TwinAx cables can trip you up (Passive/Active dependant on storage solution).
Thanks Peter and Mike
We have take exactly the same Switch (4500X)
Kndrgds,
aotholland.
4500X is not designed for "hit-less" applications.  The Nexus family of DC switches are designed for this.
