Bookmark
Subscribe
5709
activating a zoneset
wca4oi
Hello I am new to Fabric Switches.
I have added a new zone to our zoneset. The fabric only has one active zoneset and I have backed up the Fabric.
The zone I created has two FCALIAS attached.
At this point I need to activate the zoneset with the changes and I have read the command is:
zoneset activate name "Zoneset" vsan XXX
but I also found another one:
Zoneset distribute full vsan XXX
Which one should I use? We have two Fabrics but some servers are not on each fabric yet so I want it as non disruptive as possible when I change one of the fabrics..really I don't want any downtime.
Also because I inherited these Fabrics I don't know if there are any other pending changes. Is there a command to see all the new changes before I activate (or distribute)?
A show zone statistics has me a little worried with the "Number of Change Requests Recvd: 236"
Statistics For VSAN
Number of Merge Requests Sent: 2
Number of Merge Requests Recvd: 2
Number of Merge Accepts Sent: 2
Number of Merge Accepts Recvd: 2
Number of Merge Rejects Sent: 0
Number of Merge Rejects Recvd: 0
Number of Change Requests Sent: 8
Number of Change Rejects Sent: 0
Number of Change Rejects Recvd: 0
Number of GS Requests Recvd: 0
Number of GS Requests Rejected: 0
Thanks in advance!
dakester
Zoneset activate is required.  It tells the switch to enforce the changes.
Zoneset distribute is optional and can be configured to automatically distribute with activate.  This generally allows you to configure zoning from any switch in the fabric.
fcalias is distributed with zoneset distribute.
Upon activation, the fcalias is converted to pwwn in the active zoneset..
More info can be found here.
http://www.cisco.com/en/US/docs/switches/datacenter/mds9000/sw/5_2/configuration/guides/fabric/nx-os/zone_ps5989_TSD_Products_Configuration_Guide_Chapter.html
David
dakester
David
Thanks very much for the information I found it very useful.  Found there were 56 other changes besides mine pending so need to work on sorting them out.
