Callhome Link Events
pcirne
Hi, I just setup Callhome on a MDS 9148, it works fine with all the events except the port link events (up,down,failure,....)
I checked the Callhome profile and the syslogGroupPort is enabled, the link messages are logged in the syslog but I don't receive mail notifications....
Thank's for any suggestions on troubleshooting this issue!
Hi Pedro,
You hit the bug(s).
The Link Failure syslog messages are being logged as level 5.  This will not trigger a callhome.
2011 Apr  4 11:31:57 pordir03 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 1%$ Interface fc1/11 is down (Link failure)
pordir03(config)# show logging level port
Facility        Default Severity        Current Session Severity
port                    5                       5
2(critical)
5(notifications)
The Link Failure syslog messages need to be level 2 to trigger callhome.
The config has
version 5.0(4b)
logging level port link-failure 2
The config is not working. This is the bug.
9513-01# show port internal info all | i "syslog"
Global link failure syslog level = 2
    Link failure syslog level = 5  <---- config is not working at the interface level.
Options:
Wait for the next 5.x release.
Configure an snmp server to send emails for link failure traps.
Configure a syslog server to send emails for link failures.
Use RMON until you upgrade to the next 5.x release.
     Device Manager: Admin > Events > Theshold Manager.
       Select All interfaces, Link Fialures.
       Change the Sample(sec) from 10 to 30.
       Create (you may not get a confirmation, so don't click Create twice).
       To see the alarms, on bottom, click     More ... >  (top) 64 Bit Alarms
   For the callhome config, choose RMON for the full_txt callhome (default is all).
   The short_txt callhome may not contain the physical interface.
David
dakester
Hi Pedro,
It's probably these bugs.
CSCti92549    "Port logging level port link-failure 2" doesn't syslog as critical error
CSCti92353    IF_DOWN_LINK_FAILURE_CRIT not generated
If you are running 5.x, the fix will be in the next 5.x release.
   After upgrading to a release with the fix you will need to reconfigure the link-failure logging level to activate the fix.
   Config
   no logging level port link-failure crit
   copy run start
David
Hi Dakester,
The link failure events are logged:
2011 Apr  4 11:32:04 pordir03 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN 1%$ Interface fc1/11 is down (Link failure)
2011 Apr  4 11:32:04 pordir03 %PORT-5-IF_UP: %$VSAN 1%$ Interface fc1/11 is up in mode F
But no CALLHOME is made for those events, other events like a power failure are notified by CALLHOME:
2011 Mar 31 16:48:41 pordir03 %PLATFORM-5-PS_STATUS: PowerSupply 2 current-status is PS_FAIL
2011 Mar 31 16:48:41 pordir03 %PLATFORM-2-PS_FAIL: Power supply 2 failed or shut down (Serial number QCS1430K1H5)
2011 Mar 31 16:48:41 pordir03 %CALLHOME-2-EVENT: POWER_SUPPLY_FAILURE
2011 Mar 31 16:48:41 pordir03 %CALLHOME-2-EVENT: FAN_FAILURE
The CALLHOME setup is made:
pordir03(config)# show callhome destination-profile profile full-txt-destination
full_txt destination profile information
maximum message size:500000
message-level:0
transport-method:email
email addresses configured:
url addresses configured:
alert groups configured:
system
environmental
linecard-hardware
supervisor-hardware
inventory
test
cisco-tac
syslog-group-port
RMON
I did what you have suggested:
pordir03(config)# no logging level port link-failure crit
pordir03(config)# logging level port link-failure crit
port                    5                       5
0(emergencies)          1(alerts)       2(critical)
3(errors)               4(warnings)     5(notifications)
6(information)          7(debugging)
pordir03(config)# show running-config all
!Command: show running-config all
!Time: Mon Apr  4 11:44:09 2011
version 5.0(4b)
license grace-period
feature telnet
feature http-server
Hi Pedro,
You hit the bug(s).
port                    5                       5
2(critical)
5(notifications)
The config has
version 5.0(4b)
Options:
David
