04-10-2012 03:10 PM
I am using two MDS9134 Switches and I am trying to send 4G FC traffic from JDSU tester to bothe the Swiches.
This creates E-Port between the swithces and Fport where the ports are connected to the JDSU tester ports.
For all Link is up and the ports coem up correctly as E port and F ports.
When I send traffic from the tester, spmehow. traffci does not get generated.
Do I need to configure these Switches with Zone sets.
04-11-2012 05:47 AM
Yes, It sounds like you need to put the JDSU pwwns in a zone, the zone in a zoneset and activate the zoneset.
Make sure the JDSU ports are in the same VSAN and the ISL is trunking that VSAN.
David
04-11-2012 05:01 PM
Thanks David for your prompt reply.
It still does not work. Now I can send traffic from only one Switch.
Do I have to assign different VSANs for the two switches?
Currently, I have assigned both Switches the same VSAN 1 for Zoneset and I can only activate one of the Zones at a time.
I also tried re-naming zone set for the second switch, but kept the same VSAN 1 but only one zoneset of the switch is active at a time (is it due to same VSAN?)
--pravin
04-12-2012 10:29 AM
Hi Pravin,
Topology:
JDSU - MDS1 - MDS2 - JDSU
All JDSU F_ports and MDS E_ports should be in the same VSAN (or the E_ports should be trunking the same VSAN as the F_Ports).
The E_ports should not be isoloated or segmented.
show zoneset active vsan x on both switches should be the exact same.
There should be an * next to the JDSU pwwns and the JDSU pwwns should be in the same zone in the output of
You may have to open an SR on this one.
04-12-2012 10:38 AM
Thanks a lot David for detailed explanation.
I just made it work by assigning different VSANs and different Zonesets for the two switches.
Thanks for all your help.
--pravin
04-12-2012 10:40 AM
Thanks for the feedback Pravin.
You might have a different topology than I drew.
David
04-12-2012 10:43 AM
Actually I have the same topology as you drew, but between the two MDS switches, I have our own DUT.
Now I will try MDS9222i Switches and hopefully it will work.
--pravin
