11-11-2011 08:19 AM
Hi ...
I have two switches Nexus 5010 with NX_OS 4.2.1 conected to Brocade 5000 using NPV (and NPIV) features.
Now we have two new switches Brocade 5300 and we need to verify the compatibility of the Cisco Nexus NX_OS with the Brocade firmware.
I can't find any compatibility matrix with this detail.
Any suggestion ?
11-14-2011 01:00 PM
Here is the link for Nexus and Brocade interoperability Matrix
usually this table would show those models those have been tested and verified
However I do not see Brocade 5300 listed in the table . It could be, interoperability may have not been tested by both vendors perticularly to 5300 type Model.
11-14-2011 06:28 PM
We are using Nexus 5020 npv move to Brocade 5000 switch (6.4.2) without any issues. Used almose all nexus new releases 5.0 to 5.2.x
11-14-2011 07:38 PM
Is Nexus 5010 the only switch type not working with Brocade 5300?
Does this mean 5020 type works with Brocade 5300 and Nexus 5010 does not.
11-16-2011 05:56 PM
Technically issues are mostly with firmware versions and not becasue of the hardware type. There could be user configuration error as well.
11-17-2011 10:20 AM
Thanks for your comments and help.
The Nexus 5010 are connected to Brocade 5000 in NPV configuration, but we recently bought a Brocade 5300 and we want to know the compatibility issues when we connect them.
10-27-2012 08:11 AM
We have designed the SAN network with Brocade5300 connected to Nexus5596. we want to know about the campatibility of these two switches. would you please tell me about your result?
Thank you
