MDS 9506 Upgrade 4.2(9) to 5.2(2d)
Hi.
I need a help about upgrade the image. It's the first time I do by myself.
I ran:
show install all impact system bootflash:m9500-sf2ek9-mz.5.2.2d.bin kickstart m9500-sf2ek9-kickstart-mz.5.2.2d.bin
And returned:
Compatibility check is done:
Module  bootable          Impact  Install-type  Reason
     1       yes      disruptive         reset  Incompatible image
     5       yes      disruptive         reset  Incompatible image
     6       yes      disruptive         reset  Incompatible image
Is this, because I need the earlier version?
If yes, how version will I need upgrade first?
Thks.
Paulo Maurício
dakester
Hi Paulo,
It looks like you'll want a two step upgrade.
Nondisruptive Upgrade Paths if you are at 4.2(9)
http://www.cisco.com/en/US/docs/switches/datacenter/mds9000/sw/5_2/release/notes/nx-os/mds_nxos_rn_522d.html#wp778613
1. Upgrade to NX-OS Release 5.0(x).
2. Upgrade to NX-OS Release 5.2(2d).
David
dakester
Hi Paulo,
David
Thks David,
I'll make the two step upgrade.
One more time, thank you for your help.
Paulo Maurício
