MDS9509 and write erase
mariangcisco
After I ran 'write erase' command and reloaded switch, running 'sh running-config diff' gives me this result
switch# sh running-config diff
Building Configuration ...
diff: /mnt/cfg/1/ascii/system.cfg: No such file or directory
switch#
Any help ?
tblancha
There is no startup config to compare against after a wr erase. If you do a show startup, you will get:
switch# sh startup-config
No startup configuration
mariangcisco
I forgot firmware level
boot system bootflash:/m9500-sf1ek9-mz.1.3.5.bin sup-1
boot kickstart bootflash:/m9500-sf1ek9-kickstart-mz.1.3.5.bin sup-1
tblancha
You were right, I somehow thought it would create new empty startup-config. Where does it take ip address of mgmt0 then ? After restart ip address was available, admin password was set too. Which parameters are kept and where ? And is there a way how to restore all default settings ?
Thank you
The IP address for mgmt is keep on a separate file and the admin password should be just the default admin password after a wr erase.
