Nexus 5548UP information
xayavongp
Is there a way to show from the CLI whether the switch is a 5548P or 5548UP ?
I have seen the physical labeling but wanted to a way to verify via the CLI.
2 Accepted Solutions
Rick1776
Level 5
Level 5
You can run the "show inventory" command and it should show you what you need. You can also try "show version" but I don't think it shows up in that output.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/command/reference/fund/n5k-fund-cr/n5k-fund_cmds_show.html
Rick1776
Level 5
Level 5
You can also do the command "show module" that will give you almost the same output but easier to read.
Rick1776
Level 5
Level 5
Okay I see it now under PID...that was easy.
Thanks!
Rick1776
Level 5
Level 5
