Nexus 5548UP to FEX2000 fabric link
rickyteo82
Hi all,
I had setup and config the uplink for Nexus 5548UP and FEX Nexus 2248TP-E for my company
The transceivers we are using is SFP-H10GB-CU1M (Copper).
On the Nexus 5000, im able to view the transceivers details, Mode is fabric, status is up.
However on the FEX 2248TP-E, Its display transceiver is not applicable, Mode is access, status is down (Link not connected)
Can anyone pls advise me what is going on and how do I go about rectify this issue?
Does SFP-H10GB-CU1M (Copper) supported in FEX 2000? Is there any additional steps to config for the FEX?
I appreciate much for you guys prompt reply.
With Thanks and Regards,
Ricky
ahmedshoaib
Level 4
Level 4
Hi;
As per Cisco document is showing it's support SFP-H10GB-CU on FEX 2000:
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-2000-series-fabric-extenders/data_sheet_c78-507093.html
Can you explain you issue in more detail?
Thanks & Best regards;
