please explain "remote" parameter for "fcroute" command
Roman Rodichev
Level 7
Level 7
Hi, I don't fully understand the "remote" parameter on "fcrout" command. Why would someone specify it?
sw1(domain 0x64)----sw2 (domain 0x65)---sw3 (domain0x66)--660101
from sw1
fcroute 0x660101 0xffffff int fc1/1 domain 101 remote vsan 1
this is my assumption.
- 0x660101 is remotely connected via 0x65
Mostly you should not be using fcroute unless
there is a switch which does not support fspf.
6 Replies 6
beth-martin
Level 5
Level 5
The remote parameter configures the static route for a destination switch remotely connected. For more information on this read the document available at http://www.cisco.com/en/US/products/ps5989/products_command_reference_chapter09186a00801470a8.html#wp1242973
Let's say I have three switches inline A, B, and C. I'm trying to configure static fcroute for a storage device attached to C.
I would configure fcroute with "remote" parameter on switch A, specifying DID of switch C
I would configure fcroute without "remote" parameter on switch B, specifying DID of switch C
Is this correct?
Hi, I'm still not clear on this. Trying to understand when you would use remote command.
Thanks!
from sw1
I tried the same scenario as yours. I use both
from sw1
and
fcroute 0x660101 0xffffff int fc1/1 domain 101 vsan 1
I use fcping and fctrace to analyze. Actually, both can work. It seemed the parameter remote is not very important.
Hi Rodichev,
Yes, it is correct. If the fcid you wish to go, is not on the switch directly connected, you need to configure remote.
Hakan.
