04-27-2020 03:28 AM
we have a S3260 with a single server-single sioc. the 2 QSFP ports are connected to FI-A and FI-B but they are not detected. ports are orange in the UCSM page. ports of the FI are configured as server ports. any ideas?
Solved! Go to Solution.
04-27-2020 08:36 AM
Hi Ahmed,
what cables are you using and on which ports? There was a bug in the last months that servers were not discoverd with passive DAC cables (QSFP-H40G-CU3M=).
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvp77042
If you hit that bug you have to connect KVM to the server and reset the VIC settings.
Hope this helps.
04-27-2020 08:36 AM
Hi Ahmed,
Hope this helps.
04-28-2020 12:02 AM
