S3260 is not discovered on the 6332-16UP
Ahmed Wasim
we have a S3260 with a single server-single sioc. the 2 QSFP ports are connected to FI-A and FI-B but they are not detected. ports are orange in the UCSM page. ports of the FI are configured as server ports. any ideas?
Stefan Schonert
Hi Ahmed,
what cables are you using and on which ports? There was a bug in the last months that servers were not discoverd with passive DAC cables (QSFP-H40G-CU3M=).
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvp77042
If you hit that bug you have to connect KVM to the server and reset the VIC settings.
  1. Connect keyboard/monitor to the affected server
  2. [F8] to configure CIMC and enter IP address
  3. Connect mgmt port to network/laptop
  4. Access newly configured CIMC IP to access CIMC Web GUI
  5. Reset VIC to factory default (see attachment)
Hope this helps.
Stefan Schonert
Hi Ahmed,
Hope this helps.
Thanks a lot for your support.
