Serial No s for 9134s
steve switzer
Hi All
Trying to find the serial nos of a couple of 9134s.
Been on the boxes CLIs and the 'show hardware'
command seems to produce the serial no-
Switch type is : MDS UROS 9134 FC (1 Slot) Chassis
  Model number is DS-C9134-K9
  H/W version is 6.0
  Part Number is 73-10972-06
  Part Revision is B0
  Manufacture Date is Year 11 Week 44
  Serial number is FOX114416JJ
  CLEI code is COM9210ARA
From that i would assume the Serial no is FOX114416JJ
But our records say otherwise
Methinks the records are wrong - am i right
Steve
Jeremy Waldrop
Level 4
Level 4
Steve, these 2 commands will show the SN
show license host-id
show inventory
Jeremy Waldrop
Level 4
Level 4
show inventory
In addation to Jeremy, you can also do a:
show sprom backplane 1
You'll see the serial number in there. There is a secondary serial that sometimes OSM's like to have. You can find this by either looking at the front or bottom of the switch or running the following command
show sprom supervisor
enjoy
-marc
