03-28-2018 10:37 PM - edited 03-01-2019 06:18 AM
I have one nexus 5k switch, which is connected to the FI,
in my 5k switch, I have E1/11, fcoe vlan 300, connect to FI portX,
I have fc1/28 connect to FI port y, fc2/3 connect to storage target, now in show cdp neighbor,
I can't find port x and port y for my FI(fabric interconnect). how to find port x and port y?
in my 5k switch do i need to use switch trunk mode off this command for interface fc1/28 and fc2/3? thanks
03-29-2018 05:10 PM
Greetings.
FC doesn't have the exact CDP/LLDP type neighbor detection that Ethernet does.
You should be able to run the following on your N5k:
#show topology
The FI's don't run in FC trunk mode by default, so you need to disable that on the n5k side with a :
int fc x/y#switchport trunk mode off
or enable on the FIs.
Kirk...
03-29-2018 07:59 PM
1)
From N5K to look at UCS in End Host <NPV> you can use:
f241-02-08-5596-a# show fcns database local detail | i 10.10.10.1 prev 7 next 14
VSAN:501 FCID:0x0a0040
port-wwn (vendor) :20:4f:00:2a:6a:12:6e:80 (Cisco)
node-wwn :21:f5:00:2a:6a:12:6e:81
class :3
node-ip-addr :10.10.10.1 <==UCS FI MGMT0 IP ADDRESS
ipa :ff ff ff ff ff ff ff ff
fc4-types:fc4_features :npv
symbolic-port-name :UCS-FI-A:fc2/15. <== UCS FI CORRESPONDING FC PORT
symbolic-node-name :UCS-FI-A
port-type :N
port-ip-addr :0.0.0.0
fabric-port-wwn :20:89:54:7f:ee:d3:f8:80
hard-addr :0x000000
permanent-port-wwn (vendor) :20:4f:00:2a:6a:12:6e:80 (Cisco)
connected interface :fc3/9 <==N5K CORRESPONDING FC PORT
switch name (IP address) :f241-02-08-5596-a (10.10.10.2)
2)
You can also find, from UCS FI, the upstream switch and port PWWN by issuing from UCS FI:
show npv internal info external-interface all
Very useful to verify what is the connected upstream NPIV switch and upstream FC fabric port wwn, etc.
