UCS 6248UP
Toss Leey
If i have UCS 6248UP connect to UCS 2204XP, do i need Transceiver in UCS 6248UP?,  one more thing what cable type i need to provide 10GB between Extender and Fabric Switch
2 Accepted Solutions
Walter Dey
Most likely the distances in the rack allow this copper cables, which have embedded transceiver's
Table 3 SFP+ 10 Gb Ethernet Transceiver
Model
Description
SFP-H10GB-CU1M
10-Gb Ethernet—copper SFP+ (1 m, 3.28 ft.)
SFP-H10GB-CU3M
10-Gb Ethernet—copper SFP+ (3 m, 9.84 ft.)
SFP-H10GB-CU5M
10-Gb Ethernet—copper SFP+ (5 m, 16.4 ft.)
SFP-H10GB-ACU7M
10-Gb Ethernet—copper SFP+ (7 m, 22.9 ft.)
SFP-H10GB-ACU10M
10-Gb Ethernet—copper SFP+ (10 m, 32.8 ft.)
Yes ! This cables inter connect the UCS 2204XP in the Chassis with the Fabric interconnect UCS 6248UP, without requiring any other Transceivers.
5 Replies 5
Walter Dey
Model
Description
SFP-H10GB-CU1M
SFP-H10GB-CU3M
SFP-H10GB-CU5M
SFP-H10GB-ACU7M
SFP-H10GB-ACU10M
That;s mean i do not need to buy module for fabric switch, bcz SFP-H10GB-CU5M can plug in without module, Right
Hi Mr.Walter
Hope you are fine...
Do i need "Fabric Interconnect Cluster Sync" between two UCS 6248UP, if they both connect to One Chassis
Thanx
Yes, it's mandatory for a FI (6248) Cluster configuration. Distance Limitation: 100 m; copper (1G Ethernet) cable back to back, no Switch in between.
The IOM (2204/2208) in the Chassis connect only to one FI (6248); no dual homing.
IOM left, FI left, or IOM fabric A, FI A
IOM right, FI right or IOM fabric B, FI B
Walter.
