VRF IP Route Error: Interface must be point-to-point
jason.loomans
Hi.  I'm configuring a second VRF on a Nexus 5596UP to troubleshoot jumbo frames between devices.  A VLAN interface has been configured and I'd like the pings to egress out that interface.  This is the config for the vlan:
interface vlan200
vrf member iscsi
ip address 172.20.9.254/24
vrf context iscsi
  ip route 172.20.9.0/24 172.20.9.254
When I try to configure the vrf, I am assigning the static route 0.0.0.0/0 vlan 200, I get the error "Interface must be a point-to-point."  What does this mean?  How is this properly configured?
gofianto.phin
Hi Jason,
Why you need the route ? From your configuration, it seems that the route on the same network on vlan 200
vrf context iscsi
The route already directly connected, I think you don't need any route to the same segment
Gofi
gofianto.phin
Hi Jason,
vrf context iscsi
Gofi
Thank you for your response.  It turns out the route was not needed for the application.
