vSphere 4.1 + Cisco P81E + Nexus 5010: VSAN operational state:down
we have a setup with a nexus 5010 and 2 ucs c200 m2 with p81E CNA.
We have configured the nexus with one vsan, 20, and two vfc. Every cna is bound to his own vfc, and we can see the VFC up, but the vsan operational state is down...
attached the relevant part of configuration
here's the output
# sh int brie
Interface  Vsan   Admin  Admin   Status          SFP    Oper  Oper   Port
                  Mode   Trunk                          Mode  Speed  Channel
                         Mode                                 (Gbps)
vfc32      20     F      on      trunking         --     TF      auto --
vfc33      20     F      on      trunking         --     TF      auto --
nexus1# sh vsan 20
vsan 20 information
         name:VSAN0020  state:active
         interoperability mode:default
         loadbalancing:src-id/dst-id/oxid
nexus1# sh vsan membership
vsan 1 interfaces:
vsan 20 interfaces:
    vfc32             vfc33
vsan 4079(evfp_isolated_vsan) interfaces:
vsan 4094(isolated_vsan) interfaces:
7 Replies 7
The problem was linked to the fact that in CIMC we MUST set the fcoe vlan in P81E fc0 and fc1.
Hi Gianstefano,
Where do you actually configured the fcoe VLAN in the CIMC ?
Is it the "default vlan " configuration in the HBA ?
Bruno
connect via ssh
scope chassis
scope adapter 1
scope host-fc-if fc0
set vlan
commit
scope host-fc-if fc1
set vlan
commit
YOU MUST REBOOT the ucs before the change takes effect.
That's right. maily 2 parts to let systems know which vlan carry fcoe traffic
1) on N5K side, need
vlan
  fcoe vsan 20
2) on the CIMC's vHBA property
specify as the deault vlan
Thank's,
It works now
Besr regards,
Bruno Fernandes
please rate useful posts :-)
I can't seem to scope to the VIC adapter at all on my C200 M1, even though it's definitely installed and actually functions just fine. White papers show that there should be a "Cisco VIC Adapters" tab in the CIMC, but it doesn't exist for me. I've run HUU and updated everything, but no joy.
Screenshots attached.
Any ideas?
