Will Nexus 7706 combined with Nexus FEX 2248TF-E support FCoE
camo
We have a N7706 (module N77-F348XP-23) and  FEX N2248TF-E
This link says that N2248TF-E is a N2248TP-E
https://www.router-switch.com/pdf/n2k-c2248tf-e-datasheet.pdf
This link says that N2248TP-E does not support FCoE
https://www.cisco.com/c/en/us/products/switches/nexus-2000-series-fabric-extenders/models-comparison.html#~tab-1ge
This link says that N77-F348XP-23 supports FCoE
https://www.cisco.com/c/en/us/products/switches/nexus-7000-series-switches/models-comparison.html#~tab-f-series
So, at the end, Will Nexus 7706(F3) combined with Nexus FEX 2248TF-E support FCoE?
balaji.bandi
Thanks @balaji.bandi
So, both the FEX and its parent have to support FCoE?
Is that?
if you like to use parent switch as FCoE, you ignore FEX models and deploy directly on Parent switch to save resource,.
maybe your case may be different.
parent switch support.
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-7000-series-switches/datasheet-c78-730273.html
BB
