write error: No space left on device
Pereda123
Community Member
I have an MDS 9509 that is generating the message "write error: No space left on device" whenever I perform a "dir log:".
the output looks as follows:
MDS9509# dir log:
who: write error: No space left on device
         31    Jun 24 21:31:07 2008  dmesg
    3313664    Jul 19 17:57:21 2012  messages
      31999    Oct 17 19:27:55 2012  startupdebug
Usage for log://sup-local
  209715200 bytes used
          0 bytes free
  209715200 bytes total
Also, if I do a "show logging logfile" I get the same message with "Internal error in displaying logfile".
SANCore1# show logging logfile
Internal error in displaying logfile - 80050013
any advice on fixing this issue will be much appreciated.
thank you.
6 Replies 6
dakester
What does the output of
'show system internal flash' look like?
Here is the ouput:
MDS95091# sho system internal flash
Filesystem           1k-blocks      Used Available Use% Mounted on
/dev/root               204800    204800         0 100% /
proc                         0         0         0   -  /proc
none                    409600    124336    285264  31% /isan
none                    153600      3368    150232   3% /var/sysmgr
none                    204800    117360     87440  58% /var/sysmgr/ftp
none                    102400      8796     93604   9% /dev/shm
none                     40960         0     40960   0% /volatile
none                      2048         0      2048   0% /debug
/dev/hd-cfg0             39979      4439     33476  12% /mnt/cfg/0
/dev/hd-cfg1             39979      4439     33476  12% /mnt/cfg/1
none                     61440      2748     58692   5% /var/sysmgr/startup-cfg
devpts                       0         0         0   -  /dev/pts
/dev/hd-pss              39979      4543     33372  12% /mnt/pss
/dev/hd-bootflash       853240    109060    700836  14% /bootflash
/dev/hd-obfl              8779      1753      6573  22% /mnt/obfl
127.1.1.6:/mnt/bootflash/
                        853240    109060    700836  14% /bootflash_sup-remote
thanks.
You might want to click on the link to open an SR from this Discussion.
Provide the following output.
show sytem internal flash
show system internal dir /var/sysmgr/ftp
show system internal dir /var/tmp
show cores
Thanks for the info.
the commands you provided all work except the ones with "dir". It gives me an "invalid command detected" message.
MDS9509# show system internal dir /var/sysmgr/ftp
% invalid command detected at '^' marker.
SANCore1# show system internal dir /var/tmp
Thanks again.
BTW, the caret symbol is actually under "dir" not internal.
thanks.
Hello Rudy,
Since you have a MDS9509.  You can just do "system switchover" This will clear /tmp which filled up the / directory
