220 series switches - support of CISCO-ENVMON-MIB
vitaliy.isarev
How to monitor 220 series  switch CPU usage and Temperature using SNMP? Thereis support of CISCO-ENVMON-MIB in datasheet  - but when I try to snmpwalk throw oids  - switch response with "CISCO-ENVMON-MIB::ciscoEnvMonMIB = No Such Object available on this agent at this OID".  SNMPwalk throw all "ciscoMgmt" tree in atach
8 Replies 8
I have the same problem with SG220. We have also updated to the last firmware release (1.0.0.18 image) with no success (even when the 1.0.0.18 mib includes it).
When running snmpwalk to check available OIDs (quering for sysORID) we only get these:
SNMPv2-MIB::sysORID.1 = OID: SNMP-MPD-MIB::snmpMPDMIBObjects.3.1.1
SNMPv2-MIB::sysORID.2 = OID: SNMP-USER-BASED-SM-MIB::usmMIBCompliance
SNMPv2-MIB::sysORID.3 = OID: SNMP-FRAMEWORK-MIB::snmpFrameworkMIBCompliance
SNMPv2-MIB::sysORID.4 = OID: SNMP-NOTIFICATION-MIB::snmpNotifyFullCompliance
SNMPv2-MIB::sysORID.5 = OID: SNMP-VIEW-BASED-ACM-MIB::vacmBasicGroup
SNMPv2-MIB::sysORID.6 = OID: TCP-MIB::tcpMIB
SNMPv2-MIB::sysORID.7 = OID: SNMPv2-MIB::snmpMIB
SNMPv2-MIB::sysORID.8 = OID: IP-MIB::ip
SNMPv2-MIB::sysORID.9 = OID: UDP-MIB::udpMIB
It would be nice to understand why it is not implemented while it is specified in the switch datasheet.
thxia
Hi Viatliy and Sergio:
i downloaded MIBs_Sx220_v1.0.0.18.zip, and I do see CISCO-ENVMON-MIB..
I do notice that you've stated you downloaded v1.0.0.18.zip
I'm not at my lab at the moment, but I will try it when tomorrow....
Glenn
SG220 mibs
MIB exists, but switch isn`t support it.
I agree...the MIBs_Sx220_v1.0.0.18.zip file include it but there is no trace of CISCO-ENVMON-MIB when querying the switch through SNMP
Hi Sergio and Vitally:
We were able to replicate this and will be raising issue with DevEng. You will see a response shortly. Thanks for your support and patience..
Hello Glen...
Any news on this in  2019???
I see now.. Okay, I'm checking out what needs to be done.. I'll post my responses here.
Thanks for your patience,
Glenn
Hi Glenn, after three years, do you have any solution?
Sorry for necroposting, but we have the same problem with 2x SG220 50p POE and we can't get the CPU load from snmpwalk with the OID: ".1.3.6.1.4.1.9.6.1.101.1.9.0 ".
THXIA
