8 port or 16 port switch
mansoorqadir
I am using 8 port and 16 port switches in my organization. Is there any way to block the ports since there is no IOS that comes in these switches?
6 Replies 6
Leo Laohoo
I don't understand what you mean by this.
The switch is placed openly and i wanted to block the port.
If it's a Cisco/Linksys SRW or SLM series switch, then you can disable the ports from the web management GUI.
What's the exact type of your switch?
Cheers,
Tamas
the switch that i want to block the ports is SD216. Any idea
The SD216 is an unmanaged switch, so there's no way to block the ports from
software.
What you could possibly do:
  • block the ports physically: stuff something in the unused ports, like vax or something. This will void your warranty, though.
  • if you have a managed switch between this SD216 and the rest of the network, assign static MAC addresses on that switch and disable dynamic learning.
Cheers,
Tamas
I guess i will go for Patch Panel .. And thanks for the help
