07-03-2019 04:16 AM
Hi guys,
Is there any management tool that is capable of applying command changes at once to multiple switches in the same vlan ?
I'm talking about 70 switches.
Solved! Go to Solution.
07-03-2019 04:37 AM
Hi there,
You might want to take a look at Cisco FindIT:
https://www.cisco.com/c/en/us/products/cloud-systems-management/findit-network-management/index.html
...I think it does scale up beyond 70 devices.
cheers,
Seb.
07-03-2019 04:37 AM
Hi there,
cheers,
Seb.
07-03-2019 04:39 AM
Ah yes, the device limitation I was thinking of was for 10 devices in Eval mode. Beyond that each device needs a license :/
cheers,
Seb.
07-03-2019 06:09 AM
Cisco FindIT Network Manager
I'll check it out.
thank you..
08-12-2022 08:06 AM
Is it possible to use Python with Netmiko, Ansible or like way to automate these switches?
11-06-2022 01:06 AM
Python and Yaml with Ansible. Ansible is the most Cisco friendly tool out your collection.
But I've found out a more powerful and effective tool called APIC-EM. It's a Cisco free tool. It pushes config and images to devices out the box without touching the device. And it manages the whole LAN. Any config change can be easily propagated though all devices in just one click.
