Alternative for 2960 Cisco switch
ahmedmaged9432
is switch sg300-10pp Cisco can be as alternative for switch 2960 8 ports non Poe
luis_cordova
Hi @ahmedmaged9432 ,
It can be an alternative depending on the functions for what you use the switch.
As the series indicates, SMBs are for small networks and without advanced configurations.
Catalyst switches, on the other hand, have full IOS with the possibility of more advanced configurations.
I leave you these links about a discussion I found informative:
https://community.spiceworks.com/topic/1496865-difference-between-sg300-2960
Cisco recommends that the 2960 series be migrated to the 9200 series:
https://www.cisco.com/c/dam/en/us/products/collateral/switches/catalyst-9200-series-switches/nb-06-cat-mig-guide-cte-en.pdf
