08-22-2018 06:34 AM
Folks,
I have an RV340 as an Anyconnect SSL VPN server. I can successfully connect and disconnect twice with a mobile client. However on teh third attempt to connect, I reach the server, accept the banner, but the VPN disconnects. Logs are attached.
I will appreciate any assistance that I can get is resolving this issue.
08-24-2018 05:01 AM
Can you please verify the log on the RV340 Router, whether you are able to see any log which shows 'QueueNotEmpty : queue entries is empty'
Also please confirm the Firmware version running on the RV340 Router.
09-13-2018 11:43 AM
09-14-2018 03:41 AM
Thank you for your reply. The mentioned problem has already been reported (for the mentioned firmware version) and there is a bug CSCvj50141 generated for the same.
Presently the workaround are as follows…
- Only known workaround is to reboot the router
- Sometimes changing port used has helped
The mentioned bug might get fixed on the future firmware release.
09-14-2018 03:43 AM
