01-26-2019 07:35 AM - edited 01-26-2019 08:39 AM
hi guys,
I`d like to know if it`s possible to setup an authentication for the WebGUI Access via TACACS and give explicit customized permissions for configuring the switch on an ACS?
what I also cannot find in the WebGUI configuration, is the configured named authentication-lists... anyone can help?
01-26-2019 09:12 AM
Trying to understand the use case here, can you explian more, what kind of WebAuth you looking ?
01-28-2019 12:00 PM
I'd like to have a restricted access for some type of users (e.g. 1st level technican) which would use the GUI for access but do only need read-only permisson! The authentican and authorization should be done through tacacs.
02-08-2019 08:44 AM
is there any input or feedback regarding authentication and of course authorization using tacacs for the WebGUI?
