Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2946 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4537 Views
  • 1 replies
  • 16 Helpful votes
Hi, I would to change management vlan on sg200-08 switch, so created in switch vlan 100, my port ge1 which is uplink to other switch is configured as trunk, then on Management ipv4 interface I choosed vlan 100 assignet IP, netmask and gateway correct...
Tutek by Level 1
  • 819 Views
  • 0 replies
Resolved! memory upgrade
 I need to ask about the availability to upgrade the memory of the below devices i have :  1- have 2 Switches 24 PORTS CATALYST 2960 - X SERIES GigE PoE 370W 4 X 1G SFP LAN Base (WS-C2960X-24PS-L)  128 mb flash memory and 512 dram ( can i upgrade the...
Hello,On our PoE switch (SG300-52P), for the past six months or so, it seems people are randomly loosing internet via Ethernet We are supposed to have ports set to "Trunk 10UP, 20T"   Port Vlan Membership, however it seems to always reset to "1UP, 20...
leoB by Level 1
  • 2752 Views
  • 5 replies
all 19 of the APs do power up but only 13 of the 19 broadcast the SSID. others are indicated as Fault in the Web Interface (please see screenshot). we've already tried to limit the power inline to 10W but we still can't make all of the APs go fully f...
Hi All,   I'm trying to configure private VLANS for the first time on an SG300-28PP. gi3 is the connection to my router which serves as the gateway for this VLAN.    I've created Private vlan 231 that maps to private vlan 23.  The config for VLAN 23 ...
Screen Shot 2019-02-25 at 6.14.40 PM.png Screen Shot 2019-02-25 at 6.14.57 PM.png
Hello Guys,I have a SG300-10 and I am trying to route 2 vlans, I was using layer 2 SW's and both my Firewalls to route them and all was working but I want the SW to do it now. I'll try to explain my network as best as I can. So I have 2 L2 SW's and 1...
Nesperas35 by Level 1
  • 1879 Views
  • 18 replies
Hi,Currently we have switch:Model No.: SG300-52 52-PortPID VID: SRW2048-K9 V04 We wanna buy another one, which in future would replace this one, which we have. The problem is - I can't find exactly the same switch such as SRW2048-K9 V04, only similla...
Kirin by Level 1
  • 761 Views
  • 0 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
