12-27-2012 07:19 AM
Please send me the best propose for the following specification :
Switch will be used for CCTV system for up to 20 Cameras.
12-27-2012 12:17 PM
Good afternoon.
Thanks for using our forum.
Hi Mosa , my name is Johnnatan and I am part of the Small business Support community. I had seen your post and I found a switch that could help you, “Cisco SGE2010P 48-Port”, you can see it in the following link.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps9967/ps9985/data_sheet_c78-502075.html
I hope you find this answer useful, if it was satisfactory for you, please mark the question as Answered. Please rate post you consider useful.
Greetings,
Johnnatan Rodriguez Miranda.
Cisco network support engineer.
12-27-2012 12:35 PM
Hi Mosa, the only small business switch which supports 128 gbps switch capacity is the SG500X models.
http://www.cisco.com/en/US/prod/collateral/switches/ps10903/ps12128/c78-695646_data_sheet.html
It seems the smallest unit you would be looking for is a SG500X-24P which supports the 24 Gigabit ethernet ports with 4 10 GE and 2 combo 5 GE ports.
The SGE2010 supports 96 GBPS switch capacity while the SX300 models support 104 GBPS.
-Tom
Please mark answered for helpful posts
