02-26-2021 07:08 AM
We have an SF-302-08P switch.
Can I export its configuration, then import this exported configuration into a Cisco CBS-35O-8P-2G-NA switch??
How should the SF-302 config be exported?? -- exclude, encrypted, plaintext??
And how should it be imported?? -- running, startup, backup??
Thank you, Tom
02-26-2021 07:51 AM
Not that i am aware its compatable. i suggest to do offline - if you looking to upgrade the kit.
02-26-2021 07:55 AM
Are they compatible or not??
This is not an upgrade.
302 switch will remain in use, 350 is an additional switch within which we want the same/similar config as the 302.
350 switch is newer than 302 switch.
Thank you, Tom
02-26-2021 08:10 AM
as i mentioned not that i aware it support -
Other note - when you backup and restore on new device, that will conflict with Live device configurtaion, which may cause exiting network go down.
Rather i suggest good approach is, take the configuration from OLd switch - show run - from cli ( copy in to notepad,) tweak the IP / hostname other information and Paste in to new device ( Try to add few line at a time, so if any information not accepted can be noted and fixed easly) - is this works ?
Hope this make sense ?
