Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2810 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4353 Views
  • 1 replies
  • 16 Helpful votes
I have DHCP setup for a voice vlan and another test vlan with a different scope.  Phones connect and they work Until they are rebooted. On reboot  It fails to restart "DHCP: waiting for IP". Reviewing the DHCP bindings I see that the Address Type for...
When connecting Cisco Business 250 Smart switch to existing network internet speed tests dramatically drops over 50%. What can be causing this issue. Keep in mind this is when the switch is connected to another unmanaged Netgear switch. Also this is ...
john19251 by Level 1
  • 1835 Views
  • 12 replies
Hi,Previously I was configure my switched successfully 6Mbps each port for my WAP client.But I need few port config to customized.Here I want to config 1 port for bandwidth rate 20 WAP x 6Mbps each WAP with MAC allow and deny for unauthorized access....
Need  help please, I have Cisco SG-35028P switch , I have a task of creating two or three VLAN's with DHCP and internet should work for the clients. i will be using router provided by ISP for internet.   Can you please guide me. communication within ...
On Cisco SG200-50 firmware 1.4.11.5 (and before 1.4.11.4) I cannot install certificate from CA (Windows AD) after generate CSR.I have error: SSL can't import certificate - conversion of input to certificate failed.I've try path from https://severehal...
Hi everyone, i want to buy a SG550X-24F to connect some Switches. The newer ones come with a SFP+ Uplinkport but there are also some with only SFP Port. My question is, can i use 1G SFP Tranceiver in the SG550X-24F or is it really SFP+ 10G exclusive?...
Freddy86 by Level 1
  • 470 Views
  • 3 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
