07-25-2022 06:06 PM
I have problem to reset SG300-52MP switch.
The system light is not on and all port is flashing.
I pushed reset button but it does not work.
Please share any idea.
Thank you in advnace.
07-25-2022 11:22 PM
- The device may be broken , attach a console and check if any output can be observed.
M.
07-26-2022 12:31 AM - edited 07-26-2022 12:31 AM
Connect the console cable do the below the setting on the putty
Braud rate -115200
data bits-8
Parity- None
Stop bits - 1
post here what is the output written on the console.
05-01-2023 04:59 AM - edited 05-01-2023 05:00 AM
how to disable the MODE button ? (disable the factory reset function) , on cisco 1000 series switch
