Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3626 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5311 Views
  • 1 replies
  • 16 Helpful votes
We have switches with expired smart-net support that have failed to bring the interfaces up due to power inline failure during post. I formatted the flash and put images designed for non-POE switches to see if the inline power failure status during p...
I have the above device connected to my Verizon Router using the 192.168.1.2 | 255.255.255.0 for its' management IP under VLAN 1. I have ports gi2-3 configured for VLAN 100, using 192.168.100.1 | 255.255.252.0. VLAN 1 is configured as a trunk port. I...
Mork1978 by Level 1
  • 361 Views
  • 0 replies
I have Cisco SG300-28, SG350-28, and Catalyst 2960 switches. SG350-28 and Catalyst 2960 are connected to SG300-28 via a trunk. The Bridge Priority of Cisco SG300-28 is set as 4096. However, the Catalyst 2960 switch sees it as root bridge only for VLA...
sakar by Level 1
  • 2664 Views
  • 4 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
